Slice Pro Slider doesnt auto advance
Discussion in 'Slice WordPress Theme' started by lakecpc, Jul 30, 2018.
  1. lakecpc
    lakecpc New Member
    I would like for my slider to auto-advance and I would like to set a desired speed. I have searched the threads, but I believe the responses must be out-dated. Can someone help, please?
    Thank you...
  2. akbar92
    Hello Emily,
    Thanks for contacting us,
    We need WordPress admin credentials to configure it.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do it for you.
    As per your requirement, I would like to inform you that - This will require some source code (PHP, HTML, JS & CSS) customization in the theme which is time-consuming and would be done specially for you by our team.
    As per InkThemes WordPress themes and plugin customization policy, we will charge you $30 for this customization.
    Kindly, transfer the payment of $30 directly to our PayPal account.
    Here is the payment link - https://www.inkthemes.com/members/signup/Tl8pwtOFI
    Once you make the payment do share your transaction details.
    We will start customization and will try our best to deliver the customized work in a mentioned timeline.
    Waiting for your confirmation.
    Akbar
  3. lakecpc
    lakecpc New Member
    I would like to know how to do it myself if I have changes later. Is there anyway you can just provide me with instructions?
    THank you!
  4. akbar92
    First, Go to the root folder of the theme then assets->js and find & open the custom.js file then remove the text which is marked in the attached screenshot.
    Hope this helps...!
    Akbar
