Slice Pro Slider
Discussion in 'InkThemes-Support Working Hours' started by greggrsmith, Oct 22, 2016.
  1. greggrsmith
    greggrsmith Member
    any chance it's possible to enable auto advance in the new slice pro ??? http://phc-toys.com/ thanks in advance for any help.
  2. Naveen
    I have checked your site but didn't get you. Please elaborate your query a bit more.
    Warm Regards!
    Naveen Kolhe
  3. greggrsmith
    greggrsmith Member
    Is it possible to have the slider auto advance, instead of the user having to click on the forward or back arrows.... thanks.
  4. nitin
    nitin Guest
    Yes, its possible to enable the autoplay feature for the slider.
    Can you please provide us your dashboard details.
    Site URL:
    WordPress Username:
    WordPress Password:
    Warm Regards!
    Nitin
  5. mwillett
    mwillett New Member
    I would also like to have this ability. Is it possible to enable this myself?
  6. Naveen
    That will require some source code manipulation in the theme, Let me know if you are familiar with HTML/PHP/JS then, we will try to provide you solution.
    Warm Regards!
    Naveen Kolhe
