Hello, Is there a way to remove or turn off the slide-animation on mobile view. This will enhance user experience as currently slides appears only when you scroll down on smartphone devices. If mobile users who are viewing the website are unaware of the content then that can lead some of the content go unnoticed. I hope you can help me to resolve this. Thank you.
Hello, For this Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: @media screen and (max-width: 782px) { .animated.left-to-right, .animated.right-to-left, .animated.bottom-to-top { -webkit-transition-duration: none; -moz-transition-duration: none; -o-transition-duration:none; -ms-transition-duration:none; transition-duration: none; } .animation_started.animated { -webkit-transform: none; -moz-transform: none; -o-transform: none; -ms-transform: none; transform: none; opacity:1; } .left-to-right { -webkit-transform:none; opacity:1; } .right-to-left { -webkit-transform: none; opacity:1; } .bottom-to-top { -webkit-transform: none; opacity:1; }} Thanks & Regards Nitesh Raghuwanshi
