Slide not move properly
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by raaj95, Sep 24, 2015.
  1. raaj95
    raaj95 Member
    Slide not move properly after some time slide freeze.button text for slider not work and slider description not work. and please add logout option on top of the website.http://tradedp.com/
    Sorry, we didn't find out any issue in the slider as you have mentioned above, kindly check.
    As per your second issue, we will do it for you through your provided credentials earlier.
  3. raaj95
    raaj95 Member
    When i click on register WordPress login page is come ??? but in your demo when I click on register theme login page is shown... i attached two image first is your theme demo registration and second is our..
    Please provide us FTP details at [email protected]...
  5. raaj95
    raaj95 Member
    send currently 500 error show plz check and fix it thank you
  6. priya
    We have customized your theme as per your requirement..
    Kindly check and reply..
    InkThemes.
  7. raaj95
    raaj95 Member
    In front page image not shown properly a white gap is shown please find attached file.
      File size:
      60.4 KB
      2
  8. priya
    Please paste the CSS code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .productlisting .pgallery .thumbnail li img, .thumbnail li img {
        width: 198px;
    .productlisting .pgallery li .edd-image, li .edd-image {
        margin-left: 5px;
    Note: Adjust the numeric value as per your requirement..
  9. raaj95
    raaj95 Member
  10. nitin
    nitin Guest
    Hope you are doing good.
    I got your concern. I visited the link provided by you and what I found is that the image is not cropped by the theme. Actually, it is uploaded originally as a cropped images. To verify this, if you will right click on any image and then save it on your PC, you will notice that the image is cropped in original hence, it is displaying as it is (cropped).
    What you can do is check once, and then upload proper images to the section.
    You have an outstanding website out there. Wish you the best out of it.:)
    Is there anything else that I could help you upon?
    Nitin
  11. raaj95
    raaj95 Member
  12. nitin
    nitin Guest
    Fixing your issue requires some customization in the source code of the theme.
    We tried to login using the credentials provided by you earlier, but it seems that you have changed them.
    So, send us your latest website WordPress login details at [email protected] along with the thread link.
    Your Website URL:
    WordPress Username:
    Password
    We will do it for you.
    Nitin
  13. raaj95
    raaj95 Member
    Mail send....Plz check
  14. nitin
    nitin Guest
    You would be glad to know that your issue is fixed now. In future if you want to change the same then follow the screenshot given below.
    Nitin
