This is probably a simple solution, but what is the best way to speed up the homepage slider? I don't see a setting for this in the theme options. Am I missing it? Thanks! Great theme.
Go to js > custom.js present in your theme directory and decrease the value of slidespeed and play, as per your requirement. For the reference see the image given below.
Hi, I have tried several variations to this and the slider still slides every 5 seconds. I even went as far as adjusting the value to 100 and 100. I do not know what else I can do. progressivepsychsolutions.com
Hello, Could you please provide the following information listed below. Thread Link: http://www.inkthemes.com/community/threads/slide-speed.2604/ Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] We will check and try to resolve your issue.
Hello, We have changed the slider speed of your website and it is working fine. You can check your website.
Thank you, I saw that the speed was changed, but that is not the speed that I wanted, I was just showing you that I changed the value and nothing changed. Can you tell me what I can do to adjust the speed to be what my client wants? Thanks, Ed
Hello, If you are not able to edit file through FTP. Then you can also access custom.js file through your dashboard. Just install "wp-editor" plugin. And access custom.js file. Appearance > Theme editor > js > custom.js And change speed from there. Thanks & Regards Nitesh Raghuwanshi
