Hi I have recently purchased this theme and the slider is not appearing across the top of the website. The website is this one: http://www.fxmanagedforexaccount.com and i need the BLUE image to appear across the top of the website and below the menu bar for evey page. I also need the lead capture form to appear across the top of every page like the example you gave here: https://www.inkthemes.com/previews/?demo_id=29 How do i do this?
Hello, Greetings from InkThemes! Regarding your first issue, i.e. related to the slider.. You are suggested to reinstall a fresh copy of the theme from the members area and check after that. And for form related requirement, You just need to activate LeadCapture plugin in your dashboard and drag and drop that plugin in Homepage widget area (Dashboard=>Appearance=>Widget) of your dashboard. Hope it will resolve your issues.. Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
