Slider and rating
Discussion in 'ReThink WordPress Theme' started by lup31337, Jun 8, 2014.
  1. lup31337
    lup31337 Guest
    1) I want to put some text instead of the slider.
    I turned the slider off, but how do I place a title with some text there ?
    2) How do I turn off the rating system ?
  2. lup31337
    lup31337 Guest
    3) I created few categories and when i access one of them, the header reads "Category Archives: <Category name>"
    How do I delete the "Category Archive:" ?
    4) The thumbnail images for the posts are resized to fit, but they are also cropped top and bottom. How to stop it from cropping the image ?
    5) How do I remove the review form (the post comment form) ?
  3. Nitesh
    1) To add text open "loop.php" file and add your text just at the top of page.
    Check image for reference.
    2) Paste this code in Custom CSS
    .content_bar .product .index-ratting {
    3) For this open "category.php" and remove code shown in the image.
    4) For this open "loop.php" file and increase crop value. Check image for reference.
    5) Edit post and uncheck "Allow comment".
    Nitesh Raghuwanshi
  4. lup31337
    lup31337 Guest
    Problem with 1)
    When i add text there it shows on my Home page (which is great) but it shows on all the other category pages.
    I want unique text for my home page and unique text for all my categories.
  5. Nitesh
    For home page.
    open "index.php" and add text as shown in the image.
    For category page open "category.php"
    Nitesh Raghuwanshi
  6. lup31337
    lup31337 Guest
    Ok, so I got the home page sorted, but not the categories.
    If I do like you said, the text appears on all the categories.
    I want to add unique text to each individual category.
  7. Nitesh
    Nitesh Raghuwanshi
  8. lup31337
    lup31337 Guest
    How do I change the name of "Older" to "Previous page" and "Newer" to "Next page"
  9. Nitesh
    For this open 'product.php' file and search 'Older' and 'newer'. And change them.
    Nitesh Raghuwanshi
  10. lup31337
    lup31337 Guest
    I want to changed the text of the Visit Site button. I modified the loop.php file, but that only made changes to the posts on the home page or category page. If i click on a post, the text from the button inside the post is the same. How to change the text of the button inside the post ?
  11. Nitesh
    For this open "customsinglepost.php" file search text and change it.
    Nitesh Raghuwanshi
  12. lup31337
    lup31337 Guest
    <div class="full-content-page">
    <img class="top-thumb" src="<?php echo $test_image; ?>" alt="img"/>
    <div class="top-head">
    <h3 class="top-title"><?php echo $head_Text_area; ?></h3>
    <p><?php echo $desc_Text_area; ?></p>
    <center><a class="visitsite" target="self" href="<?php echo $link_url; ?>">Visit Website</a></center>
    </div>
    </div>
    </div> <?php }?>
    This is the code in which i found something relevant. But the button reads "Visit the site" not "Visit Website". I didn't find the exact string (Visit the site).
    If I change it, nothing happens.
  13. Nitesh
    Ok, It's an image 'visit-btn.png'.
    You can edit it from
    You can use photoshop or any other image editing tool for editing.
    Nitesh Raghuwanshi
  14. lup31337
    lup31337 Guest
    where can I access that file ? Using c-panel ?
    If so , how ?
  15. Nitesh
    You can access it through.
    FTP or by c-panel.
    Nitesh Raghuwanshi
  16. lup31337
    lup31337 Guest
    OK, So i changed the button how I liked. Then I noticed there is a different button for mobile version. I changed that as well.
    But on the mobile version I saw there are some issues.
    The read button is not showing correctly, some pictures inside the post do not resize correctly.
    The site is gramophonecity.com . Please check it on your phone.
  17. Gourav
    .content_bar .product {
    padding-bottom: 55px;
    .content_bar .product img.postimg {
    width: 180px;
    float: none;
    Gourav Shrivastava
  18. lup31337
    lup31337 Guest
    That fixed the button, but the pictures inside the post are still cropped (on the phone).
  19. Piyush
    .content_bar.product_detail .feature_content img {
    max-width: 100%;
    height: auto;
