How would I change the animation style for the slider text, such as a dissolve, as well as change the timing of the slide transitions, either slower or faster transition times?
Hello, You can change the speed of the slider by changing the value of "Play" in custom.js file. This file is available in the "js" directory of your theme directory. If you increase the value then the speed will be decreased and if you decrease the value then the speed will be increased. You can change the vakue according to your requirement.
Hi, Where is the custom.js file, please. I am trying to do the same thing, but don't know where to look.
For solution follow link given below. http://www.inkthemes.com/community/threads/slider-description-box.1935/
