Slider box - transparency not working
Discussion in 'BlackBird WordPress Theme' started by tasvia, Jun 3, 2013.
  1. tasvia
    tasvia New Member
    Recently I used:
    .flex-caption {
    background: rgba(20, 19, 19, 0.25)!important;
    .. to get it more transparent. It worked great. During the weekend you guys corrected an error for me in which the blog-posts didnt appear on the front page (www.tasvia.se), which is now fixed and great. But for some reason, the slider box is back to being fully non-transparent. Ive checked, removed and re-entered the styling code above, but its not affecting the slider box at all. Any idea what could be wrong?
    The styling-code for making the box-text white is still working, however. Its just the opacity issue.
    Daniel
    We have checked your website and your slider caption box background is looking transparent. I think you have solved it by yourself.
  3. tasvia
    tasvia New Member
    It's not transparent for me, at least while using Internet Explorer (i have no means to use other browsers atm). I have had two friends, also with internet explorer, that has seen it before when transparent, to try it now. Both of them are having solid dark gray, which means no transparency.
    (I have no friends online with other browsers atm)
    Daniel
  4. Gourav
    Paste this code in Custom CSS
    .flex-caption {
    opacity: .55; /* Standards Compliant Browsers */
        filter: alpha(opacity=55); /* IE 7 and Earlier */
        /* Next 2 lines IE8 */
        -ms-filter: "progid:DXImageTransform.Microsoft.Alpha(Opacity=535)";
        filter: progid:DXImageTransform.Microsoft.Alpha(Opacity=55);
  5. tasvia
    tasvia New Member
    That made a big differance. Thank you!
