Slider caption does not appear on iPhone
Discussion in 'Woodpecker WordPress Business Theme' started by charlc, Apr 9, 2015.
  1. charlc
    charlc Guest
    The caption text that appears on the slider does not seem to display on iPhone -- only the image is shown (seen with 5S running iOS 8.2). (Caption is fine on iPad running same iOS).
    You can check this directly at cubemc.staging.wpengine.com
  2. praveen
    praveen Support Staff
    Hi, Chalrc!
    There is no need to worry.
    Actually, it is the default feature of the theme that hide slider caption text in small screen devices.
    Because, due to responsive nature of theme, the slider adjust its size according to screen and the same happens with the caption text which becomes too small in small devices and makes the website look ugly.
    Hope you will understand.
    Praveen
