Slider description box color change
Discussion in 'BlackBird WordPress Theme' started by ekim2wheels, Apr 3, 2014.
  1. ekim2wheels
    ekim2wheels New Member
    How can I change the slider description box color? Please see attached file.
    Thanks.
    .flex-caption {
    background: red;
  3. ekim2wheels
    Hi Piyush,
    The vertical line that divides the 4 buttons and the text disappeared. How can I keep the vertical line while changing the color?
  4. Gourav
    Remove the code provided above.
    and go to images directory present in your theme directory and replace your image with present caption background image or edit it.
    The name of image is "cap-bg.png"
    Gourav Shrivastava
