slider descriptor links
Discussion in 'Infoway WordPress Theme' started by cjackson, Feb 5, 2014.
  1. cjackson
    cjackson New Member
    How can I get the home page slider descriptors link to the pages with the images?
    Gourav Shrivastava
  3. cjackson
    cjackson New Member
    That's too bad, but thanks. If anyone has implemented this and can share some direction, that would be appreciated!
  4. Gourav
    I have tried, What you are asking and there is one solution available for you.
    Go to the Appearance> Theme Options > Slider Settings panel in your dashboard and paste the code given below in the Slider Description section.
    <a href="Enter your page link here">Enter your Description text here</a>
    Gourav Shrivastava
  5. cjackson
    cjackson New Member
    I tried that, and it breaks the text in the tabs - see attached. I also tried replacing the code <a href="#fragment-2"> in the frontpage.php file with link code as well, and although it linked the text for all but the first element without breaking it as it appears in the attached, it resulted in breaking the image rotation. I am not sure how to easily address this, but if you have any other ideas, please let me know. Or if anyone is interested in making a couple bucks to provide some assistance, please post a response here.
  6. Piyush
  7. cjackson
    cjackson New Member
  8. Piyush
    The link code doesn't works in the text box and we put our header text in the text box for slider caption, so the link code will not work for header.
    It will work for the description area because we put description in the text area.
    So remove the link code from the header section and apply it in the description section (Appearance> Theme Options > Slider Settings panel >Slider Description section).
    This will work fine.
  9. cjackson
    cjackson New Member
    I did enter the code that Gourav suggested in the "First Slider Description" section under the slider settings, so I am not sure what you are asking me to do that is any different than what I already tried? Please explain.
  10. Piyush
  11. Piyush
