Slider doesn't work on mobile - Letters not shown
Discussion in 'One Page Pro WordPress Theme' started by georgiladakisd, Dec 22, 2016.
  1. georgiladakisd
    georgiladakisd New Member
    Hi, we are using the pure out of the box theme. The letters / headlines in the slider work fine in desktop mode, but not in mobile. Please see attachment. any ides? this is urgent. thanks
  2. Naveen
    For your information, the slider captions is hidden for small screens as it becomes unreadable for the small screens.
    Hope you find the above information helpful.
    Warm Regards!
    Naveen Kolhe
  3. georgiladakisd
    Ok so this is not supported. Is there any way to make it happen? Any adjustment or piece of code or plugin? (I am a software engineer so please feel free to answer in technical terms, I will understand.) Thank you
  4. shruti26
    shruti26 Guest
    I got your concern!
    It requires some customization in the source code of the theme, for which we need access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password :
    Thanks & Regards,
    Shruti Jain
  5. georgiladakisd
    Thanks for this, I have shared the details on the email above today.
  6. shruti26
    shruti26 Guest
    Alright!
    We will do it and let you know once it is fixed.
    Your patience will be highly appreciated!
    Thanks & Regards,
    Shruti Jain
  7. shruti26
    shruti26 Guest
    I would like to tell you that you issue has been fixed!
    We have used this code in your Custom CSS Section:
    .slider_caption h2,
    .slider_caption p {
       display: block;
    .slider_caption .slider_sep {
       width: 33%;
       display: block;
       margin: 0 auto;
    Feel free to contact us if you have any questions.
    Thanks & Regards,
    Shruti Jain
    amaconline likes this.
