Slider Dropped Down
Discussion in 'RoadFighter WordPress Theme' started by erinbro, May 31, 2013.
  1. erinbro
    erinbro Member
    Heres my problem it's the same or close: http://obsvideotech.com/ the slider has dropped below the menu. It seem to have pushed it's way into the featured area.
    Here it us the correct way per the start of a demo...http://demo2.weupgradewebsites.com/ what need I do gentleman... thanks in advance.
    By the way it is a BADD-ASS theme, keep up the good work :D
    PS: can the appointment plugin be used on other themes??? if so which ones...
    Go to Settings > Reading
    and follow the instruction as shown in image given below
    All InkThemes themes are compatible with Appointment plugin.
