Hello, How can I get the flex caption wrapper that appears on slider1 to appear on all sliders. Please see URL http://www.martialartscenterforhealth.com/wp/ for example.
Hello, Go to Appearance > Theme Option > Slider Settings > Second Slider Heading/Second Slider Description and enter your text there. Use same process for others also. Thanks & Regards Gourav Shrivastava
Thank you for the response. I can understand that if we were using the h1 and the paragraph text. However we are only using the image that is based on the first slide no text at all. We have placed those elements as display:none; in the css. We only want the image css/color/images/caption-bg-red.png to appear on all the slides. Attached is the image we replaced with the base image from the template.
