Slider Header and Description
Discussion in 'ButterBelly WordPress Theme' started by rgonzalez9332, Sep 5, 2016.
  1. rgonzalez9332
    rgonzalez9332 New Member
    I would like to center both the header and description within the colored bar below the images. Can you also proved the css to change the font family as well?
    Thank you
    Please paste the code given below in Custom CSS field (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .flex-caption {
        text-align: center;
  3. rgonzalez9332
    Thank you that worked great. Would I be able to change font-family using the same class as well?
  4. rgonzalez9332
    I would also like to change the background color but when I do using the code below the transparency is lost and I can still see blue. Please see picture
    .flex-caption-wrapper {
    background: #grey;
  5. priya
    Sorry..didn't get your issue..
