Slider Heading and Description
Discussion in 'ColorWay WordPress Theme' started by 1stopnonprofitshop, Nov 15, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    How do you have the slider heading and description show up immediately and not a few seconds after the image shows up?
    theme1.1stopnonprofitshop.com
  2. nitin
    nitin Guest
    To turn off the animations, just paste the code given below in Custom CSS section
    .salesdetails{
     /*CSS transitions*/
     -o-transition-property: none !important;
     -moz-transition-property: none !important;
     -ms-transition-property: none !important;
     -webkit-transition-property: none !important;
     /*CSS transforms*/
     -o-transform: none !important;
     -moz-transform: none !important;
     -ms-transform: none !important;
     -webkit-transform: none !important;
     /*CSS animations*/
     -webkit-animation: none !important;
     -moz-animation: none !important;
     -o-animation: none !important;
     -ms-animation: none !important;
    Hope this helps...!
    Nitin
