Hello there, 1. on my site the background oft the slider heading and section is not transparent like in your demo. Its just a black background. How can I fix that? 2. And I would need below that Slider and additional section/area. (Like your "Feature Tabs Area" in the demo, but it should be a fullwidth area...to enter some more text an maybe some images about the company. After that then should appear "Über unsere Stores" and "Anmeldung zum Newsletter" > For easier understanding I have create a screenie. And another question. 3. Can I change the typo font for all <h1> <h2> etc...our clients does not like the Ü Ä and Ö in the demo font...so it would be great if I can add for that simple another font... Thank you very much for your help. Greetings Miriam
Hello, 1>Use the following CSS code : - Code: .flex-caption { background: none; } 2> Please follow the screenshot given below. PHP: <div class="grid_24"> <div class="my_custom_text_section"> Write your text here... </div> </div> <div class="clear"></div> Now, paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .my_custom_text_section { text-align: center; padding: 20px 25px; background: gray; } 3> You can use any font you your choice. Use the CSS code : - Code: h1, h2, h3, h4, h5, h6{ font-family: arial !important; } Please change font-family according to your requirement. Thanks, Praveen
Hi there, my problems 1) and 2) are solved Thank you very much. on 3) the code in custom css not work... I tried to change the font for all headings in the css file, but it seems that this will be ignored from the browsers? (i removed the font in style.css know it looks like that: Code: h1, h2, h3, h4, h5, h6 { font-family:'verdana', 'Lucida Grande', HelveticaNeue, 'Helvetica Neue', Helvetica; !important font-weight: normal; color: #010101; } But it unfortunately not works that way.. Can you further help me? Thanks, Greetings Miriam
Hello, Miriam! My mistake... In ButterBelly Theme, cufon.js is used which converts the text/headings into images. So before applying any changes in the texts/headings you must have to disable it. Please follow the screenshot given below to disable cufon.js. Now, you can apply you CSS. Thanks, Praveen
