Slider images are distorted and slider size
Discussion in 'One Page Pro WordPress Theme' started by sleepingbee, Oct 14, 2016.
Tags:
  1. sleepingbee
    sleepingbee New Member
    Two questions on this lovely theme:
    1. What can I do to prevent the slider from grossly distorting the images that are uploaded? I'm using high-res images but they are getting stretched badly when used in the slider.
    2. Is there any way to have the slider take up less height on the page?
    thanks much
    http://f68.36f.myftpupload.com/
  2. Naveen
    You are requested to use images of recommended size there (800 X 437).
    This will resolve your issue,
    Warm Regards!
    Naveen Kolhe
  3. sleepingbee
    Hi Naveen - thanks, I did that and it looks better. Anyway to make the slider take up a less tall amount of space on the page?
  4. Naveen
    That will require lots of CSS modification for the slider that will be time-consuming as well.
    It would be better if you can use any slider plugin like https://wordpress.org/plugins/smart-slider-3/
    Let me know, we can integrate the above plugin in your site.
    You can send a request along with this thread URL at [email protected]
    Warm Regards!
    Naveen Kolhe
