Slider images are not linking to URL
Discussion in 'Cloriato WordPress Theme' started by pangeaseed, Mar 13, 2013.
  1. pangeaseed
    pangeaseed Member
    Greetings -
    I just noticed that all my homepage slider images aren't linking to any of the URLs I have designated.
    Could you provide me the CSS code to reactivate the link?
    Akira
    You have activated non responsive theme, That's why links are not working.
    Go to the Appearance > Editor / front-page.php and replace it completely with the file attached.
  3. pangeaseed
    pangeaseed Member
    Actually, as of now, I haven't activated the non-responsice theme yet.
    Could there be another reason for the images not working?
  4. Nitesh
    Please do let us know your website link.
  5. pangeaseed
    pangeaseed Member
  6. Piyush
  7. pangeaseed
    pangeaseed Member
    Greetings -
    I have successfully installed the updated non-responsive Cloriato Pro theme which fixed the mobile view.
    However, I would still like the slider images to link to the URLs. - Is there any way to activate the links without having to install the responsive theme.
    If you could provide me the CSS code, that would be great.
    Also, I have tried to remove the 'read more' links on the home page by adding
    .feature_content .read_more {
    However, the 'read more' links are still visible.
    Our website URL is www.pangeaseed.org
    Thanks for your assistance.
  8. pangeaseed
    pangeaseed Member
    Also, I would like all fonts to be 'Helvetica' and not the preset.
    Unfortunately, it switched back when I updated the theme, although I had it set before.
    Thanks!
  9. Nitesh
    To make slider images clickable download file attached in the first post and replace it with your current theme front-page.php (Appearance > Editor / front-page.php)
    For font issue:
    You have missed '}' in custom css after this code
    h1,h2,h3,h4,h5,h6,a,p{
    font-family:Helvetica!important;
    That's code below it are also not working.
  10. pangeaseed
    pangeaseed Member
    Greetings Nitesh -
    Thanks so much for the help.
    Slider images are clickable now and the "read more" has disappeared.
    The only two things that are now pending are
    1. the headers on the front page as well as all other pages still appear in the pre-set font. - I would like it to be Helvetica. It was Helvetica before but changed back to the pre-set typeface after updating the theme.
    2. if you look closely on the screenshot attached, you see that the footer area is 2px smaller than the body. how can I fix that?
    Thanks so much!
  11. Nitesh
    1) Paste this code in Custom CSS
    #menu .ddsmoothmenu li li a:link, #menu .ddsmoothmenu li li a:visited {
    font-family: Helvetica!important;
    b, strong {
    font-family: Helvetica;
    2) Are you getting footer issue in any particular browser or in all?
    Because your site is looking fine at my side in nearly all browsers.
  12. pangeaseed
    pangeaseed Member
    Greetings -
    thanks for the response.
    the footer issue was resolved. I just had to empty my cache.
    for the pre-set font issue, it still doesn't fix it using the code you sent me.
    my custom CSS now looks like the following; is there anything that is conflicting?
    if you could have a look at it and let me know, I would appreciate it.
    Thanks!
    .top_cornor {
    background:none;
    body {
    background-repeat: repeat;
    background-position: center top;
    background-attachment: fixed;
    background-size: cover;
    .body-content {
    background: rgba(255, 255, 255, 0.8)!important;
    width:1000px;
    h1 {font-family: 'Helvetica';
    font-size:15px;
    font-weight:400
    h2 {font-family: 'Helvetica';
    font-size:20px;
    font-weight:400
    h3 {font-family: 'Helvetica';
    font-size:16px;
    font-weight:400
    h4 {font-family: 'Helvetica';
    font-size:20px;
    font-weight:400
    h5 {font-family: 'Helvetica';
    font-size:20px;
    font-weight:400
    h6 {font-family: 'Helvetica';
    font-size:20px;
    font-weight:400
    .table{
    border:none;
    td, th {
    border:none;
    background:transparent;
    #columns {
    width: 900px;
    #columns .column {
    position: relative;
    width: 46%;
    padding: 1%;
    border: none;
    #columns .left {
    float: left;
    #columns .right {
    float: right;
    #commentsbox {display: none}
    #slides .caption{
    display:none;
    .flex-caption {
    display:none;
    .home_description {
    display:none;
    .home_text h1 {
    .home_text {
    #slider_pag ul {
    display:none;
    .logo img {
    width: 100%;
    .widget_inner.lebo.last img {
    width: 30%;
    padding:0px 10px 0px 0px;
    .body-content {
    width: 988px;
    font-family:Helvetica!important;}
    b, strong {
  13. Nitesh
    Your css code is correct.
    The problem is because of cufon.
    Go to the Theme directory > js > custom.js and remove code given below from there.
    //Font replace
    Cufon.replace('h1')('h2')('h3')('h4')('h5')('h6');
    It will resolve your problem.
  14. pangeaseed
    pangeaseed Member
    Thanks! Worked out!
  15. pangeaseed
    pangeaseed Member
    One more question.
    On may pages there is a difference in font typeface and color in some paragraphs.
    e.g. if you visit http://pangeaseed.org/issues/coastal-development/ you will see that the first paragraph is a different font and grey-colored.
    This is happening on every page and often, attempting to fix it manually doesn't work.
    Also, spacing of paragraphs changes on its own.
    What code could I use to fix this?
    Thanks!
  16. Gourav
    td, th {
    color: red!important;
    font-family: symbol!important;
    p{
    Inplace of "symbol" put your font type.
