Slider Images linking strangely
Discussion in 'ColorWay WordPress Theme' started by knleib, Jun 2, 2015.
  1. knleib
    knleib Member
    When you click on my slider images you are redirected to a new window so essentially there are 2 pages open for my site. Can this be deactivated so they aren't live links?
  2. Sobhagya
    Sobhagya Guest
    Could you please provide us URL of your website along with some edited screenshot of your issue so that we can assist you accordingly?
    In case you are unable to create a screenshot, you can follow the link http://www.screenpresso.com/ which will help you to create screenshot easily.
  3. knleib
    knleib Member
    There is nothing to take a screenshot of. my url is www.kristinlouis.com.
    Again my slider images are working fine but if you click on the image a new window opens to my site which seems unnecessary. how to disable?
  4. praveen
    praveen Support Staff
    Hello, Kristin!
    It is a feature provided for user to set an URL for each image so that when an user will click on the image, it will redirect him to that particular link which will open in a new window.
    If you don't want this feature for your slider image, then some customization in the source code will be needed to disable this feature.
    As we have your dashboard credentials, so if you want to disable this feature then allow me to use your credentials to access your dashboard and customize your website.
    Praveen
  5. Sobhagya
    Sobhagya Guest
    Hello Knleib,
    Hope Doing Good.
    Kindly follow the below step mentioned in the image.
    Hope it will solve your issue.
  6. knleib
    knleib Member
    Hi Praveen,
    Yes you have my permission. Thanks for your help.
  7. praveen
    Hello,Kristin!
    I have resolved your issue.
    Please have a look at your website.
    Hope you are enjoying InkTheme services :):) .
    Do let me know if you need any help.
    Praveen
  8. knleib
    knleib Member
    Thank you Praveen. It is not linking anymore however the text color has changed from black to blue somehow.
  9. praveen
    Hello, Kristin!
    I have fixed the issue.
    Kindly check.
    Praveen
  10. knleib
    knleib Member
    Thank you.
