Slider images not loading
Discussion in 'Themia WordPress Theme' started by itsallgeektome, Feb 17, 2013.
  1. itsallgeektome
    itsallgeektome New Member
    http://dodeathwatch.com
    I updated today and now the images are missing from the front page slider. I did some customization and added more slides, which worked fine until the update. The images are showing in the theme options page, and the box is in place on the front page but the images won't load. Your help is appreciated.
  2. jtucker276
    jtucker276 New Member
    I'm experiencing the same problem. The box is there, but no images are loading...
    Anybody?
  3. Piyush
    This problem might be occur when we are not created the menu.
    So, Create the custom menu from the menu panel (Appearance > menus) in the dashboard.
    And Check whether slider works or not.
    If you are not want to display the menu in your website then, firstly create your menu and then paste this code in Custom CSS
    (Appearance > Theme Option > Styling Option > Custom CSS )
    .menu_wrapper {
    jtucker276 likes this.
  4. jtucker276
    That fixed it for me. Thanks!! :D
  5. wilson2k4
    wilson2k4 New Member
    I upgraded to pro and I can not load a slider image... I uploaded the image in the menu but it will not post on the home page. Please help.... What was mentioned above does not work
  6. Gourav
    Do let us know your website link.
  7. itsallgeektome
    I've tried both and I still have no slider images. Help! http://dodeathwatch.com
  8. Piyush
    Your website is very slow due to which we are not able to access it.
    For your issue please provide the following information listed below so that we can provide you the solution.
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
  9. trishcostello
    trishcostello New Member
  10. Piyush
  11. Piyush
    We checked their website and found that the slider images are displayed there.
    Please check your website and specify your issue more clearly.
  12. chumber
    chumber New Member
    I upgraded to the Blackbird Pro but when I try to edit my website, it tells me I am still using the Lite version and don't have access to the slider and other upgradeable options...what do I do?
  13. Gourav
  14. chumber
    chumber New Member
  15. Gourav
    @chumber,
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will install Pro theme for you.
  16. Gourav
    Support mail sent.
