Slider Info H1 Remove Newfoundland Dogs text
Discussion in 'Squirrel WordPress Theme' started by mguilliams, May 17, 2016.
  1. mguilliams
    mguilliams New Member
    How do I remove the newfoundland dogs text from slider info H1.
    www.v-a-l-s.org
    I am unable to access your site as it takes too much loading time...
    Kindly check your site..
  3. mguilliams
    The newfoundland text appears on the mobile home page. You should be able to access the site now.
    I checked your site and didn't get any text as you have mentioned in your post..
  5. mguilliams
    The text only shows up when I view site on my iPhone. Would you please check on a mobile device.
  6. priya
    .slider-info p {
