I removed the gray slider captions (on the right side) using the following code: Code: .showcase-thumbnail-container{ display:none; } After I did this, the area where the gray slider caption area was is now white space, layering on top of my image... Is this normal? If not, how can I fix this? I don't want my image clipped on the right side. Any suggestions would be appreciated! www.mobilealertsolutions.com Thank you
I edited the front-page.php to remove this slider heading and description box. Remove or comment out this code in 5 places. Make a backup of the front-page.php file first. <div class="showcase-thumbnail"> <div class="showcase-thumbnail-content"> <?php if (inkthemes_get_option('inkthemes_slidehead1') != '') { ?> <h3><?php echo stripslashes(inkthemes_get_option('inkthemes_slidehead1')); ?></h3> <?php } else { ?> <h3>Infoway Theme </h3> <?php } ?> <?php if (inkthemes_get_option('inkthemes_slidedesc') != '') { ?> <p> <?php echo stripslashes(inkthemes_get_option('inkthemes_slidedesc')); ?></p> <?php } else { ?> <p>Premium Wordpress Theme</p> <?php } ?> </div> </div>
