Slider issue
Discussion in 'Woodpecker WordPress Business Theme' started by greatscottfilm, Aug 9, 2018.
  1. greatscottfilm
    greatscottfilm Guest
    Hi Akbar,
    You guys added some code for one of my sites that was going to make it possible to add more than 5 sliders to the main page in woodpecker. There is some shortcode in there that is supposed to add multiple sliders but it is not working or more thank likely I am adding it wrong. Can you look at it and see what might be done? On this issue, it's been a while and the client would like to get this fixed if possible. Thanks a bunch.
    http://palmbeachselect.com/
  2. akbar92
    Hope you are doing good...!
    I just visited your website but didn't notice the issue as you mentioned above.
    So that we can deliver you an exact and appropriate solution.
    Akbar
  3. greatscottfilm
  4. greatscottfilm
    The 5 regular sliders work fine, I need the shortcode to work so I can add more than 5 sliders :) Let me know if you want to take this on and I will send you a login by email.
  5. akbar92
    Yes, we are waiting for your email.
    Akbar
  6. greatscottfilm
    Ok I sent the login over to you Akbar, thank you
  7. akbar92
    We have successfully received your credentials and is being forwarded to our developers, we will get back to you with a positive response ASAP.
    Warm Regards!
    Akbar
  8. greatscottfilm
    Akbar,
    As usual, You are AWESOME!!!!!
    Thanks Akbar for taking care of that, the slider is working perfectly now.
    Scott
  9. akbar92
    You are most welcome Scott!
    Always feel free to ask your queries at our support forum: http://inkthemes.com/community/ and at our email [email protected]
    We would be glad to assist you...
    Have a nice day!
    Akbar
