Hello, my site was working fine and the slider was loading correctly until recently. I'm not sure if I have changed a setting or messed up some code, but the pictures just don't rotate any more. This is on all the pages on the site. Do you have any ideas what I can do to correct it? Here is the link: www.stjustuscatholicparish.co.uk. I've been reading about this in both this forum and the old one but nothing I seem to do makes it work again. I look forward to hearing from you.
Hello, First of all deactivate all the plugin which you have installed, sometimes plugin create problem with the theme, if then also problem exists then, download the theme again from the members area, and replace it with the current theme, it might solve your problem.
