Hi, This issue seems to appear many times on the forum. Apart of asking to check if the options are selected in "Featured listing" and "listing type", what is the solution to problem. Sometimes, it worked and when you add a listing or make any change, it stops working. If you post the solution, this will help everybody that has this problem or simply correct the issue. For now, it is not working for me either. Thx for you assistance
I'm afraid the slider isn't working for me either, ever since I installed the version 1.6. This particular issue, along with the others that I haven't had fully answered yet are just causing major delays in actually going live. Don't you think it would be a good idea to have a few beta testers from around the globe to test your new themes and their full functionality, before actually selling them? I'm sure there's a few members on this forum, me for one, that wouldn't mind helping you out. For instance, I know you guys do speak good English, however, some of the wording in a few of the elements just sound like they were written in haste and with broken English. Anyone on this forum with English as their first language... I'm almost sure would help you out and correct you with the proper wording. Also, rather that just updated the theme with a latest version that really isn't much difference from the previous, why not just tell us which folder to go into, so that some of us that do understand the basics of modifying code can fix the problems ourselves? I'm probably not the only one in this forum that would agree with the above! I am beginning to spend way too much time on here, instead of spending time promoting my directory. A refund on this theme could be looming! Thanks!
So how did you get version 1.6 as each one I download is 1.5 ??? You're not wrong on the other points as there is also a lack of attention to minor detail which is unacceptable if you are selling this theme in the West! It looks bad as a selling point for the site although the theme is good otherwise.
The Top Slider on the Homepage shows the listings which are tagged as "Feature on Homepage". Check the images below and let me know, if you are doing the step below. If submitting listing from frontend If submitting listing from Admin Backend
