Hi there I changed theme homepage so that the full blog posts now appear rather than excepts. However, I'd still like the slider to appear but isn't. Not sure if it some CSS I put in or otherwise. www.bohopreneur.com Am I able to have full blog post on homepage as well as a slider? And if not, how do I get the slider back to work with just showing blog excerpts? As at the moment it doesn't show the slider if I go back. Thanks, Hayley
Hello Hayley ! The slider shows the images from blogs according to category. So it is necessary to use images in blog posts. You can set the category images for slider from Appearance=>Theme options=>Homepage Settings. Thanks & Regards Pramod
