slider not working properly
Discussion in 'Digital Affiliate Box WordPress Theme' started by sandradohn, Apr 3, 2017.
  1. sandradohn
    sandradohn Member
    HI There, When I add a second slider it displays under the first slider. How do I correct this? I have attached a screenshot. The site is getmore5starreviews.com Thanks, Sandra
  2. Naveen
    We will have to check your site and will let you know.
  3. sandradohn
    sandradohn Member
    Hi There, I just tried adding a second slider and had the same result. It showed up below the first slider so I removed it. Have you had a look to see what is wrong? Thanks, Sandra
  4. sandradohn
    sandradohn Member
    Hi There, Can you let me know about this issue? Thanks, Sandra
  5. Naveen
    Hello Sandra,
    As InkThemes has been receiving a high volume of support requests our developers are busy at this moment, I will try to pull them on your issue and will get back to you with a positive response ASAP.
    Hope you understand..
    Warm Regards!
    Naveen Kolhe
  6. sandradohn
    sandradohn Member
    Ok, thanks for your reply. Sandra
  7. Naveen
    I am glad to inform you that- Your issue has been fixed, Kindly visit your site and acknowledge us for the same.
    Warm Regards!
    Naveen Kolhe
  8. sandradohn
    sandradohn Member
    Hi There, Thanks for fixing the slider issue. Now the header has gotten much bigger and does not look right on page. I have attached a screen shot. Can you let me know how to fix this? Thanks, Sandra
  9. Naveen
    Hi Sandra,
    For this, you need to paste the below custom CSS code in Dahshboard->Theme Options->Styling settings->Custom CSS field.
    .header .logo img {
            max-width: 100%;
    This will help you to figure it out and resolve the issue(s).
    Warm Regards!
    Naveen Kolhe
  10. sandradohn
    sandradohn Member
    HI There, Ok, I pasted the code as advised and now the header is super small....How do I adjust it to be the correct size like before? Thanks, Sandra PS I attached a screenshot of the header issue.
  11. sandradohn
    sandradohn Member
    Hi Again, I just went back on the site and the header is the correct size. Maybe I had a cashing issue. Anyway, all is fine now with the header. Thanks, Sandra
  12. sandradohn
    sandradohn Member
    Well, I spoke to soon. When I scrolled down the page, the slider issue is back now that the header is corrected. Please let me know how to fix the slider. When a second image is put in the slider , it displays below the first one like before. Thank,s Sandra Screenshot is attached...
  13. Naveen
    Please check again, it's working fine on your site.
