Hi, I'm just starting my new site using roadfighter theme I would like to ask if the feature slider on the homepage is suppose to change automatically from one slide to another slide as it does on desktop. I have just checked it on my mobile and the slider does not change at all, the slides only change if I 'touch' slide from one to another.. Please advise, Thanks.
Hello, Warm Wishes from InkThemes, The slider is getting animated on the mobile view too, you can check the theme's demo from here: https://www.inkthemesdemo.com/wptheme/roadfighter-interiordesign/ If it is not animating on your end then kindly share the kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will look into the issue and let you know the needful. Regards, Shemaela InkThemes.com
