Slider Problem
Discussion in 'BlackWell-WordPress Business Theme.' started by koraydalkilic, Dec 11, 2017.
  1. koraydalkilic
    koraydalkilic New Member
    I setup the theme but my slider is not looking right.
    It look like this. How can I solve this problem? Or can you?
    url: perdeatolyesi.net
  2. akbar92
    I didn't get you, will you please elaborate your query a bit more with the help of edited screenshots so that we could assist you accordingly.
    Looking forward to hearing from you.
    Akbar
  3. koraydalkilic
  4. akbar92
    We need WordPress admin credentials to figure out the issue.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
  5. koraydalkilic
    Thank you for fixing it but there is a new problem occured after the fixing. You can see at perdeatolyesi.net
    Can you fix that too?
  6. koraydalkilic
    I am still waiting.
  7. akbar92
    We have successfully received your credentials and is being forwarded to the concerned department, we will get back to you with a positive response ASAP.
    Warm Regards!
    Akbar
  8. koraydalkilic
    Problem is countinues. When will someone look at it?
  9. akbar92
    I am glad to inform you that- Your issue has been fixed, Kindly visit your site and acknowledge us for the same.
    Akbar
  10. cleanhom
    cleanhom New Member
    Nairobi
    i think blackwell theme has coding problems because i have had the same problem including other code errors for long. I would kindly suggest your coding team to relook at the theme again and give us an update
  11. akbar92
    Thanks for suggesting us, I would like to tell you that - We have fixed these issues in the updated version of the theme.
    Still, If you are facing problems then just send the below-mentioned credential details here.
    We will do the needful.
    Akbar
