Slider - Right Navigation Menu
Discussion in 'Infoway WordPress Theme' started by patoh777, May 1, 2013.
  1. patoh777
    patoh777 New Member
    Singapore
    Question 1 :
    I've noticed that the Theme Option - Slider Setting.
    and noticed that I have no problem saving Slider 1, 2, 3 and 5...
    but when trying to save Slider 4, the system does not seem to be able to save it....
    any idea if this is a bug?
    See example : www.asiacoachalliance.com
    (Observe that the 4th Slider cannot be changed.
    Any idea what to do?
    Question 2 :
    How to change the big text between the Sliders and the Featured Contents?
  2. Harmeet
    Harmeet Support Staff
    We have checked your website and all the slider images are working fine. You can check your website. Sometimes problem exists due to wrong path of the image so check the path while uploading the images.
    And to change the text below the slider go to
    "Appearance -> Theme Options -> Features Settings -> Feature Page Settings"
    You can easily change the text here.
    patoh777 likes this.
