Slider settings, change grey side description area
Discussion in 'Infoway WordPress Theme' started by ajyorthodontics, May 2, 2013.
  1. ajyorthodontics
    ajyorthodontics New Member
    I'd like to change the color of the description area of the sliders from dark grey to opaque-translucent white - if this isn't possible, to just remove the description area completely. How can I do this?
    How do I create a drop down links, so when the user clicks on a question, it opens up the text pertinent to this question.
    1.For your first issue
    It is not possible to change its color because it is an image not a color If you want to change its color then, Go to images directory present in your theme directory and replace your image with present tab images or edit it.
    The name of image is
    1."tbg.png"
    2."slider-sepnew.png"
    3."slidertextbgnew.png"
    2.For your second issue
    Go to
    APPEARANCE / MENUS
    Create a custom menu and only add the pages that you want to show in the navigation bar.
  3. wesmands
    wesmands New Member
    Changing the images above worked for desktop width but the"Slider Heading Background" color stays grey on the mobile width. Any idea how I can change the mobile color also?
  4. Piyush
  5. ajyorthodontics
    How would I remove the grey description boxes on the right of the sliders completely? Are there any options to change the transitions of the images?
  6. Piyush
    #featured ul.ui-tabs-nav {
    This will remove the grey description boxes from the slider.
