Slider settings in Figero
Discussion in 'Figero WordPress Theme' started by rmvc, Aug 22, 2013.
  1. rmvc
    rmvc Member
    I'd like to change the slider timing - where do I find the setting ?
    Go to Js > Custom.js present in your theme directory and adjust the value of Play by increasing the value the slider speed decreases,and by decreasing the value the slider speed increases .
    Sending image for reference
  3. daria369
    daria369 Member
    I uploaded the plugin and did lots of research in my Cpanel, found the place of /*--------DDsmoothmenu Initialization--------*/ -
    but there is no
    play: 6000,
    in it, and even if there was, I can't seem to change anything in that directory.
    Can anyone please provide more detailed instructions because the Figero static page slider really is way too slow.
  4. Piyush
    Could you please share us your website link so that we can provide you exact solution.
