Hi, I've got two questions regarding the slider on my theme. 1. The back end gives an option to add a click through URL on each slider - however, even when inserted, this doesn't work. Has this been disabled or can you tell me how I can insert? 2. Currently as the page loads (Even on a high speed connection) the slider takes a long time to load and the text overlaps. I've checked the images to make sure they are small enough, but they are sitting at around 300kb each - so it can't be that. Have you guys had this issue previously? Otherwise I'll have to check with my site host. Site here: http://www.lornascakery.com/ Any help would be appreciated. Thanks Louise
Hello, When you click on slider caption heading then you will redirected to the given link, the function is used in the heading of the caption. And the jQuery takes little bit time to load that is why your slider looks slow, and when it loads completely then you won't get any problem in it.
Louise, your site is beautiful. I love what you've done with it. I'm having the same issue with my slider text at www.harpseminar.com. They've said it's just standard with this theme. Kim
