Slider + Sort Problems
Discussion in 'GeoCraft WordPress Theme' started by krisspao, Jun 19, 2013.
  1. krisspao
    krisspao Guest
    I have to issues with the "geocraft theme", also here is my website : http://about-saintmartin.com/
    1 - In entertainment/Adult Entertainment i have a "Premium" Listing witch i selected to be in the "Feature on Category Page Slider" but does not show up ?
    2 - I bought the "Taxonomy" plugins you spoke about to sort the order of the Categories, but as you can see in Entertainment again, the list sort by date of entry ?
    If you could have any solutions for those 2 problems, you will make my day.
    Thanks in advance.
    Kriss
  2. krisspao
    krisspao Guest
    Anyone have an answer to my problems ????? Please
  3. Nitesh
    Hello Kriss,
    I think this issue is occurring because of listing category slug.
    So go to the
    Business listings > Listing categories
    Leave slug blank and then update category.
  4. krisspao
    krisspao Guest
    Hi Nitesh, i did what you said, but WP automatically fill the slug, i can't leave it blank.
    Any other idea ???
  5. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check your issue.
  6. Gourav
    Issue resolved, Please check your website.
  7. krisspao
    krisspao Guest
    Thanks a lot, the slider problem i solved.
    What about the sort listing problem ? Do you have any idea ?
    Regards
    Kriss
  8. Nitesh
    Hello Kriss,
    We have also checked your "Taxonomy" plugins we have set it to ascending order.
    And your categories are displaying as desired.
    Plugin contain it's own settings you can change them according to your requirement.
  9. krisspao
    krisspao Guest
    Thanks a lot for everything. What you said work. My only problem is ; maybe i did not explain properly, the taxonomy of the categories are perfect, but the listing stay in the order i enter them, is there any way to have them ordered fro A to Z or not ?
    I had an idea but did not have the time to try as yet : if i export the csv file, order it properly in excel and imoort it back, will the listing ordered good ot not ?
    Cordial Regards
    Kriss
    P.S Small add-on, i just tried the csv export/import, it just add the same entries over (so bad idea)
  10. Nitesh
    For this go to the
    Appearance > Editor > front-page.php
    and search "paged". You will get 2 search results. Add code given below at both as shown in the image attached.
    'orderby'=>'title',
    'order'=>'ASC',
  11. krisspao
    krisspao Guest
    Hi Nitesh,
    I did what you said at both places, but does not change anything???
      File size:
      49.3 KB
  12. Nitesh
  13. krisspao
    krisspao Guest
    Hi Nitesh,
    I'm feeling so sorry about that issue, cause i download the plugin, installed it and still NO CHANGES.
    I know you try hard, but i really need that to be done and i don't find any solution myself neither. Any other idea?
    Thanks a lot
  14. Nitesh
    Hello Kriss,
    After installing plugin go to the "Business listings". Drag and drop listings from there according to your need.
    It consume time and required every time after new listing publish. But it is the only solution.
    krisspao likes this.
  15. krisspao
    krisspao Guest
    Hi Nitesh,
    Perfect for me, anything take time, especially to make money, so its not a big deal to manage that.
    Thanks a lot again for your help and patience.
    Have a great day
    Nitesh likes this.
