Slider speed, font size and test spacing
Discussion in 'Dzonia WordPress Theme' started by molatin, Mar 6, 2013.
  1. molatin
    molatin Member
    How can I adjust the slider speed, font size and test spacing? Thanks
    1.For your first issue
    Go to
    Js > Custom.js
    present in theme directory and adjust the value of play by increasing the value the slider speed decreases,and by decreasing the value the slider speed increases .
    2.For your second and third issue.
    Please explain your problem with the help of screenshot, where you want to change the font size and text spacing and also share the link of your website, so that we can give you the exact solution.
  3. rogerschnur
    rogerschnur Member
    Gourav: when you say go to js > custom.js in theme directory, can you be more specific as to which file in the Editor section I'll find this setting for slider speed?
  4. Gourav
    You will not get theme directory in your dashboard.
    You can edit custom.js file through FTP.
    Open your Theme directory (through FTP) > js
    Download custom.js file from there, Edit it, Then again upload it.
  5. rogerschnur
    rogerschnur Member
    Thanks, I figured that out last night!
