Hello, Is it possible to alter (slow down) the speed with which the slider pictures and supporting text change on the homepage? It goes a bit too fast by default and therefore the text is difficult to read. Thanks very much for your reply. Regards, Erwin
Go to Js > Custom.js present in theme directory and adjust the value of play by increasing the value the slider speed decreases,and by decreasing the value the slider speed increases . Sending image for reference
I also want to slow this down, but I'm not sure where this JS > Custom.js is.. I have looked in each Template, in the style sheets, and I'm lost. Can you help me?
Hello, You will not get js directory in your dashboard. You can edit custom.js file through FTP. Open your Theme directory (through FTP) > js directory > custom.js Download custom.js file from there, Edit it, Then again upload it at the same place. Also follow the link given below http://www.inkthemes.com/how-to-edit-internal-files-through-ftp/07/ I hope it will helps you.
