Hi. Thank you for your help on my previous questions. I downloaded the newest version of infoway and the slider works perfectly. However the speed option is missing so I cannot adjust the speed. I was wondering if you will again use this feature or if it is permanently deleted. Thank you.
The slider speed function through Dashboard is creating problem in slider, Therefore it is removed from there, But if you want to change the speed of slider then go to Js > Custom.js present in your theme directory and adjust its value by increasing the value the slider speed decreases,and by decreasing the value the slider speed increases . Sending image for reference
