Slider speed
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by medinachaz, Dec 5, 2013.
  1. medinachaz
    medinachaz Member
    I was having issues finding out how to change the slider speed in salejunction.
    Go to js > jquery.slitslider.js present in your theme directory and adjust the value of "interval" by increasing the value the slider speed decreases,and by decreasing the value the slider speed increases .
    Sending image for reference
  3. Nitesh
    For other users:
    We have added speed option in the theme options penal.
    You can download updated theme from your members area.
    Nitesh Raghuwanshi
  4. medinachaz
    medinachaz Member
    Where is JS located? I've looked for it in editor.
  5. Piyush
    You will not get theme directory in your dashboard.
    You can edit jquery.slitslider.js file through FTP.
    Open your Theme directory (through FTP) > js
    Download jquery.slitslider.js file from there, Edit it, Then again upload it.
    Follow the link given below.
    http://www.inkthemes.com/how-to-edit-internal-files-through-ftp/07/
    I hope this will help you.
