Help! The rotating slider on the homepage is not showing up when my display screen is completely maximized. When I decrease the size of the display screen, the rotating slider appears. The main menu/sub menu is not displaying correctly. The gray background on the submenu is no longer visible and the last menu item hangs off the screen. The website link: www.reachmem.com A quick response is greatly appreciated. Thanks so much! Courtney P.
Hello, I think this is a plugin issue. So deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). Thanks & Regards Nitesh Raghuwanshi
