at the site at http://quotaalstonville.com/ the slider will not display - it just shows posts it's been working fine for years but all of a sudden it won't display the settings and images seem to be fine can you take a look please i will email the log-in to support@
Hello Smarta, Since you are using the lite version of ColorWay theme, I ould like to inform you that, the updated version of ColorWay Lite comes with Home Page template that, you need to apply on your WordPress page. Just create a Page called Home and apply the Home Page template from Page Attribute section then, visit Dashboard->Settings->Reading and set Home as your static page for the Front Page display settings rather using the latest posts option. Then, you need to configure your Home page Menus from Dashboard->Appearance->Menus just replace the custom link Home tab with your Home page tab and save your Main Menu. I hope this will resolve your issue. If you still unable to do so then, please share your WordPress admin credentials here, we will do the needful. Do let me know if you need further assistance, I will be glad to assist you, Warm Regards! Naveen Kolhe InkThemes.com PS: Just activating the PRO version in your WordPress will not require the above settings.
ok - I changed it back to Pro and it reinstated the home page but it had lost all its images & settings it seems somehow to have swapped the theme back to the Colorway standard it has been fine for many years should I remove the standard and any other themes form the admin so it does not do it again?
I have checked your site and found that, you are using an older version of the theme. You are requested to get download the latest version of the theme from your members area and use it on your site. If you still get the same issue then, I will do the needful on your site, All you need to share the admin credentials at [email protected]. Warm Regards! Naveen Kolhe InkThemes.com
