site is www.toryslanding.com I tried to download the new theme version, re zip it with a new name, but it would not re install with the error message 'Installation Failed. CSS File not found' Can you please help Thank you
Hello, Greetings from InkThemes! You are kindly suggested to reinstall the theme once again and check after that.. If still will not resolve your issue, please share your dashboard details at [email protected] along with this thread link and I will do it for you.. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Thank you Priya. If I install the theme again, will it be necessary to reenter all the home page info such as general setting, logo, favicon, slider settings, home page setting, etc? or will it retain the data from the prior install. I am hoping not to have to re enter all the site data .. do you not supply a 'update theme' function?
Hello, Don't worry.. You will not lose your dashboard configuration after upgrading the theme... Note: If there is any source code customization in the theme, only that source customization will undo.. Hope you will get it.. Thanks & Regards! Priyanka InkThemes.com
