Hi! I have purchased the all-theme package. I was wondering if there is a way to use the slider style on Black Rider with Butterbelly or maybe other plugins that comes with other themes on the package and vice versa? Thanks in advance!
Hello, Both themes have there own different layout. It is not possible to merge there style. If you want to use leadcapture plugin then do let me know. As you have full membership of InkThemes so i will send you "leadcapture plugin". You can add it at footer or at sidebar widget area. Thanks & Regards Nitesh Raghuwanshi
Hi Nitesh. Thanks for your response. I would love to receive the leadcapture plugin. I also would like to request that if possible just send it to [email protected] so I can have my assistant install it for me. Appreciate your help much. PS - I really like the themes you have and I am expecting more great things from your team.
Hi Nitesh. Thanks for the plugin. I already received it. By the way, for the rest of the plugin that you offer, do I need to pay more for them or can I get them with my membership?
