sliders not working with Wordpress 4.5
Discussion in 'Andrina WordPress Theme' started by kbrad613, Apr 21, 2016.
  1. kbrad613
    kbrad613 Member
    When my site updated to the new version of Wordpress, the sliders stopped working. Is there an update to fix this issue? Thanks!
    Could you please give a try to reinstall your theme once again and see if this resolves the problem?
    Download the Andrina theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder andrina like andrina_new,
    Again, you would need to create a zip file of that renamed folder (say: andrina_new.zip),
    Then, activate your theme,
  3. briangladstone
    briangladstone Member
    I too have the same problem.
    Both the slider, as well as the drop down menu are not functioning.
    url is www.toryslanding.com
    The solution you have described above does not work.
    I followed the instructions, and downloaded Andrina again and changed the name to andrina_new.zip.
    However it still gave the error message
    Destination folder already exists. /home3/briangla/public_html/toryslanding/wp-content/themes/andrinatheme/
    Theme install failed.
    regardless of the new name
    Do you not have a simple 'Update Theme' function?
    Can you advise how to fix the problem?
    Your immediate response is appreciated. Thanks
    Brian Gladstone
  4. briangladstone
    sorry i posted this twice by mistake .. see more recent post
  5. priya
