Hello, Its there a code to add to have the menu appear by default on smartphone. Rather than clicking the little box
Hello jordielindstorm! As i previous said for you according to your website(blackwell theme) Unfortunately ! this is not possible. We are using many files for menu if we do any code manipulation it will create issue for all views . You can make changes on click buttons. Thanks Pramod
