Hi all, I am a Dzonia user. I don't use sendmail of local VPS, but another SMTP mail server from mail space provider. I installed wp-mail-smtp plugin, the test mail is OK. Unfortunately, the Contact Form Page dosn't work, it still delivers to sendmail. Need a help. Thanks !
Hello, Theme using WordPress default mail function. If you want to use another mail space provider than you need to configure it manually or you can contact with there plugin related support forum, they will help you.
Can i config php to support smtp mail on contact page ? I did following but it dosn't work. first: nano pluggable.php: ... $phpmailer->IsMail(); to $phpmailer->IsSMTP(); then: nano class-phpmailer.php: ... public $Mailer = 'smtp'; public $Host = 'smtp.xxx.com'; public $Port = 465; public $SMTPSecure = "ssl"; public $SMTPAuth = true; public $Username = '[email protected]'; public $Password = 'xxx'; Thanks!
Hello, Its required lots of customization to replace current WordPress mail system with any other mail system. If you want to do so then please contact to freelancer for this issue. They will help you.
Solved. I created a php to set mail parameters(require wp phpmailer & smtp), then modify the template-contact.php file. It seems that everything is OK. Thanks.
