So Many Problems !
Discussion in 'GeoCraft WordPress Theme' started by leelee, Dec 18, 2012.
  1. leelee
    leelee Member
    Australia
    i'm about at the end of the line with this theme, here's my list of problems so far;
    emails do not get sent to new registered user
    google map does not show in new listing
    cannot edit text in some custom fields
    featured slider disappears after a few seconds when viewed on mobile device
    I have invested too much time into getting to know this theme to give up, but admit i'm almost there, can support react to the obvious problems all users are having ?
  2. Neeraj
    Neeraj Administrator
    1. How did you tested the email thing, when I registered yesterday I got an email of registration. Attached Image: http://screencast.com/t/wAvOYPYie
    2. The Google Map appears through the latitudes and longitudes field since you deleted them from your custom fields your map is not appearing.
    Create the field again with naming html variable 1. 'geo_latitude' 2. 'geo_longitude '
    input type would be "geo input"
    3. In which custom field are you unable to change the text ?
    4. I viewed your site on iPhone and the slider looks fine, which mobile device are you using to view your site ?
    The issues users are experiencing are based on different usage environment and you may or may not experience the similar issues too.
