Hi there, I have downloaded the SalesJunction theme from the your portal today. The following problem is occuring: When you add a custom-menu the first social icon is duplicated and the rest show on a new row, and the same problem occurs when you add an image to the fourth footer widget area, only that the problem then only occurs on the "shop" page. Please refer to this website: www.dbo.co.za
Hello, The "Payfast" code that you have added in the fourth footer widget area was creating this issue. You have missed '</a>'. But now all is fine. Please check it. Thanks & Regards Nitesh Raghuwanshi
