Some help please..
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by mariogarcia1, Feb 28, 2015.
  1. mariogarcia1
    mariogarcia1 New Member
    I have just installed the salejunction theme and i am getting to grips with it, but the instructions seem to be limited, and i have a few bits i can work out how to edit. So any help would be appreciated.
    The issues are:
    1, How to remove the buy now button from the slider
    2, Where do i edit the Grab Customer Attention text are on the homepage
    3, Where do i edit
      • Single Click Installation
        SaleJunction theme is very simple and easy to use. It just requires a single click to get installed and you can activate it on your website.
      • [​IMG]
        Responsive & Compatible
        SaleJunction is completely responsive and looks nice on all mobile devices. The theme is compatible with all latest browsers.
      • [​IMG]
        E-commerce
        SaleJunction has all those features that will make your e-commerce website easily. The theme is well compatible with shopping cart plugins.
      • 4, How do i edit the section of the homepage
    Show Your Latest Posts
    Here you can showcase your latest blog and let users know about your recent activities.
    and the post section below
    5, How do i change or edit the content of the third footer areas where i can see Products Category, Links and theme features sections..
    6, Is there anyway to replace the slider images with a video
    7, Is it possible to move, remove or not show the cart information on the header of the homepage.
    8, Can i add other social media icons to the footer of the homepage
    So i know this is a lot of questions but i thought it best to get them all out the way as quickly as possible.
    Any help would be really appreciated.
    Kind Regards
    Mario
  2. Pramod
    Pramod Guest
    Hello Mario !
    Please go to Appearance=> Theme Options and fill all information.
    You can change all by default content from theme option.
    Pramod Patel
